Hickok 600A tube tester
Yup Did that.. Was able to get it sort of working..I think it has something to do with the power cord..If I plug it in to different sockets I get different readings.. So will replace it first to see if that's it..
Skip
Hickok 600A tube tester - by vecher - 03-03-2018, 09:20 PM
RE: Hickok 600A tube tester - by vecher - 03-03-2018, 10:09 PM
RE: Hickok 600A tube tester - by gregb - 03-04-2018, 12:02 AM
RE: Hickok 600A tube tester - by morzh - 03-04-2018, 12:33 AM
RE: Hickok 600A tube tester - by vecher - 03-04-2018, 12:45 AM
RE: Hickok 600A tube tester - by gregb - 03-04-2018, 08:28 AM
RE: Hickok 600A tube tester - by morzh - 03-04-2018, 11:20 AM
RE: Hickok 600A tube tester - by vecher - 03-04-2018, 03:00 PM
RE: Hickok 600A tube tester - by morzh - 03-04-2018, 03:20 PM
RE: Hickok 600A tube tester - by vecher - 04-03-2018, 02:15 PM
RE: Hickok 600A tube tester - by morzh - 04-03-2018, 03:14 PM
RE: Hickok 600A tube tester - by vecher - 04-03-2018, 03:32 PM
RE: Hickok 600A tube tester - by vecher - 05-17-2018, 09:11 PM
RE: Hickok 600A tube tester - by morzh - 05-17-2018, 09:21 PM
RE: Hickok 600A tube tester - by vecher - 05-17-2018, 09:30 PM
RE: Hickok 600A tube tester - by vecher - 07-01-2018, 08:29 PM
RE: Hickok 600A tube tester - by Phlogiston - 07-01-2018, 11:44 PM
RE: Hickok 600A tube tester - by morzh - 07-02-2018, 08:49 AM
RE: Hickok 600A tube tester - by vecher - 07-02-2018, 01:44 PM
RE: Hickok 600A tube tester - by John R - 07-02-2018, 06:21 PM
RE: Hickok 600A tube tester - by vecher - 07-02-2018, 08:34 PM
RE: Hickok 600A tube tester - by vecher - 07-03-2018, 08:22 PM
Eico 232 VTVM Schematic
There are currently 6602 online users. [Complete List]
» 3 Member(s) | 6599 Guest(s)
