*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
Threads: 46
City: Gap Mills Wv 24941
i moved on to increase the wattage on the 40ohm power resistor.
i had a few choices and went with a 50ohm 10W resistor that seemed to take it really well with no heat sync.
i fabricated up a friction type metal bracket to pinch this new resistor up against the chassis then connected all my normal wires.
works fine so far.
you can see this new resistor and its placement in the upper left of the set up under that angle flange.
Image(s)
RE: *Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED - by jcassity - 07-02-2018, 09:35 PM
Users browsing this thread: 32 Guest(s)
Dan;
I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic?
Whatever is chosen for the spider, the material must be compatible with popular adhesives...
Th...Chas — 05:05 PM
Mike;
I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM
There are currently 7005 online users. [Complete List ]» 1 Member(s) | 7004 Guest(s)
