RCA 110K2 Unexpected project
Threads: 44
City: Menlo Park
State, Province, Country: CA
Some good clues! Nostalgia air has an entry for this radio including the Riders "Simplified Schematics" This has proved to be a big benefit in understanding which coils are in circuit. for each band.
..I now know the presets won't work until L28 for the AM band is repaired. Other stuff should fall in to place - I read elsewhere that the mica caps in these sets can be problematic also. All good stuff to dig into.
RE: RCA 110K2 Unexpected project - by EdHolland - 07-02-2018, 11:29 PM
Users browsing this thread: 28 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10097 online users. [Complete List] » 2 Member(s) | 10095 Guest(s)
