  • 1 Vote(s) - 4 Average
*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
#99
A piece of copper braid RG-59 coax makes dandy shielded cable, but note corrosion resistant type is usually difficult to tin and solder.
Many older sets had the wire run inside a closed coil spring type shielding..
Tom
RE: *Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED - by 35Z5 - 07-02-2018, 11:30 PM
Users browsing this thread: 32 Guest(s)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7290 online users. [Complete List]
» 2 Member(s) | 7288 Guest(s)
