Please help identify this Silvertone
Hi, I stumbled on this thread while searching around the web looking for info on the radio my wife inherited from her uncle. Turns out I have the very same Silvertone 7181 that you have. It still works, though some restoration is in order--at least it wasn't painted black! I'll post a pic if you're still pursuing this project. Thanks, Josh
Please help identify this Silvertone - by Guest - 12-16-2008, 09:43 PM
Re: Please help identify this Silvertone - by BDM - 12-16-2008, 11:57 PM
Re: Please help identify this Silvertone - by Guest - 12-17-2008, 04:51 PM
Re: Please help identify this Silvertone - by Guest - 12-18-2008, 10:12 PM
Re: Please help identify this Silvertone - by Guest - 07-13-2010, 05:13 PM
