Philco 41-315 Code 121 Pilot Lamps?
I had same problem on a Philco 38-3.  After reading Ron's article on rebuilding pilot lamps (see link below), I used a heat gun to soften the rubber so I could then extract the bulbs.  Can't help on the bulb numbers.
http://philcoradio.com/phorum/showthread...pilot+lamp
Larry
Philco 41-315 Code 121 Pilot Lamps? - by NV3G - 07-04-2018, 03:05 PM
RE: Philco 41-315 Code 121 Pilot Lamps? - by LarryFS - 07-04-2018, 04:18 PM
RE: Philco 41-315 Code 121 Pilot Lamps? - by NV3G - 07-05-2018, 08:45 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3566 online users. [Complete List]
» 2 Member(s) | 3564 Guest(s)
