Zenith 7G605 Transoceanic - the Clipper
Well, this is the first ever multi-SW-band portable radio. Has to be somewhat complicated. Icon_smile
But in reality it is not that complex, other than the connections to things around the chassis; the chassis itself is no more complex than any comparable tube count radio with more than one band.
RE: Zenith 7G605 Transoceanic - the Clipper - by morzh - 07-05-2018, 10:00 AM
Users browsing this thread: 17 Guest(s)
There are currently 8619 online users. [Complete List]
» 2 Member(s) | 8617 Guest(s)
