Philco Chassis for Identification
The year prefix (37-XXX, 38-XXX, etc.) wasn't used until the 1937 model year. So a 650 is only that (not a 37-650).
The 37-XXX models were also the first to have the much maligned separate RF chassis / 'unit construction'.
Anyway, based on this info:
http://www.philcorepairbench.com/socket-layouts/
I don't think that's a 650 chassis.
Maybe 660?
Philco Chassis for Identification - by GregL - 07-05-2018, 04:22 PM
RE: Philco Chassis for Identification - by Nathan Slingerland - 07-05-2018, 04:32 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 04:43 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 05:41 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:00 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:08 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:38 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:59 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 08:27 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 09:22 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 09:54 PM
There are currently 9343 online users. [Complete List]
» 1 Member(s) | 9342 Guest(s)
