Philco Chassis for Identification
Well that's nice to hear Ron.
Do you happen to know the difference between the 660 and the 665?
I just want to be absolutely certain what I have when I take it in for servicing.
Greg
Philco Chassis for Identification - by GregL - 07-05-2018, 04:22 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 04:43 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 05:41 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:00 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:08 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:38 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 06:59 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 08:27 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 09:22 PM
RE: Philco Chassis for Identification - by GregL - 07-05-2018, 09:54 PM
There are currently 4343 online users. [Complete List]
» 1 Member(s) | 4342 Guest(s)
