Zenith 7G605 Transoceanic - the Clipper
(07-05-2018, 08:03 AM)morzh Wrote:  The stuff on the cap.....it seems greasy, not dusty. And it is on one side of the cap. If it is cadmium-based, where did it come from and why is it there?
This is what happens to cadmium plating when it deteriorates over the years. I think it usually occurs as a result of the radio being stored someplace like a barn or basement.
For the sake of your health, put on a respirator and gloves, get some suitable cleaner for metal and get that stuff off your tuning condenser! (And do this outdoors!)
RE: Zenith 7G605 Transoceanic - the Clipper - by Ron Ramirez - 07-06-2018, 01:44 PM
Users browsing this thread: 17 Guest(s)
There are currently 8895 online users. [Complete List]
» 2 Member(s) | 8893 Guest(s)
