I'll Bet You Noticed - I Sure Have
#61
Oh I dunno…..back in the 80's in addition to tons of other audio gear I already owned, I came upon a used pair of Bose 901's and the equalizer box. They sounded great in the right room, and when driven HARD. Definitely king of the virtual soundstage back then.
RE: I'll Bet You Noticed - I Sure Have - by 35Z5 - 06-07-2018, 10:06 PM
RE: I'll Bet You Noticed - I Sure Have - by Arran - 06-08-2018, 03:59 AM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 03:52 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 06:42 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 07:30 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 08:51 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-08-2018, 09:15 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 09:40 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-08-2018, 10:27 PM
RE: I'll Bet You Noticed - I Sure Have - by Arran - 06-09-2018, 02:03 AM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-09-2018, 12:02 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 12:05 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-10-2018, 12:15 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 12:47 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 02:27 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 03:48 PM
RE: I'll Bet You Noticed - I Sure Have - by 35Z5 - 06-10-2018, 05:37 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 06:39 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-10-2018, 10:07 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-11-2018, 12:19 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-11-2018, 05:21 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-12-2018, 10:05 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-15-2018, 02:47 PM
RE: I'll Bet You Noticed - I Sure Have - by 35Z5 - 06-22-2018, 09:03 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-22-2018, 09:40 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 04:48 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 05:02 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 05:32 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 05:44 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 06:25 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 06:45 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 07:01 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 08:01 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 08:04 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 10:57 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-08-2018, 03:42 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-08-2018, 04:42 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-08-2018, 04:43 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-08-2018, 05:00 PM
