I'll Bet You Noticed - I Sure Have
#67
(07-07-2018, 05:32 PM)rdnzl Wrote:  Why do receivers have tone controls?
It's OK to bash most of Bose's products. but until you've heard a vintage pair of 901's pushed by 165 watts RMS per channel,  set up in a large enough room, and properly placed, you are missing out on the one thing they did OK on.
So your receiver did not have tone controls? I don't know, I usually run everything flat. If I was building a receiver it probably would not have tone controls. What kind of cut/boost does the equalizer have?
RE: I'll Bet You Noticed - I Sure Have - by 35Z5 - 06-07-2018, 10:06 PM
RE: I'll Bet You Noticed - I Sure Have - by Arran - 06-08-2018, 03:59 AM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 03:52 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 06:42 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 07:30 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 08:51 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-08-2018, 09:15 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-08-2018, 09:40 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-08-2018, 10:27 PM
RE: I'll Bet You Noticed - I Sure Have - by Arran - 06-09-2018, 02:03 AM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-09-2018, 12:02 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 12:05 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-10-2018, 12:15 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 12:47 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 02:27 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 03:48 PM
RE: I'll Bet You Noticed - I Sure Have - by 35Z5 - 06-10-2018, 05:37 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-10-2018, 06:39 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-10-2018, 10:07 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-11-2018, 12:19 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-11-2018, 05:21 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-12-2018, 10:05 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 06-15-2018, 02:47 PM
RE: I'll Bet You Noticed - I Sure Have - by 35Z5 - 06-22-2018, 09:03 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 06-22-2018, 09:40 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 04:48 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 05:02 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 05:32 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 05:44 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 06:25 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 06:45 PM
RE: I'll Bet You Noticed - I Sure Have - by Phlogiston - 07-07-2018, 06:55 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-07-2018, 07:01 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 08:01 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 08:04 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-07-2018, 10:57 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-08-2018, 03:42 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-08-2018, 04:42 PM
RE: I'll Bet You Noticed - I Sure Have - by rdnzl - 07-08-2018, 04:43 PM
RE: I'll Bet You Noticed - I Sure Have - by morzh - 07-08-2018, 05:00 PM
Eico 232 VTVM Schematic
