old radio philco 3985
Here are some pictures of mine and some I found on the net that show examples of 1.5/90V combination A-B batteries.
[Image: http://i75.photobucket.com/albums/i305/m...pboard.jpg]
Note that they use several 1.5 batteries connected in parallel (all the plus ends connected together and all the negative ends connected together) so that the useful lives of the A battery and B battery will be nearer the same. The voltage is still 1.5 volts, but the amp hours add together.
Ron Mc/
old radio philco 3985 - by Guest - 07-11-2010, 10:14 PM
Re: old radio philco 3985 - by rghines1 - 07-12-2010, 06:20 PM
Re: old radio philco 3985 - by TexMac - 07-18-2010, 02:07 PM
Re: old radio philco 3985 - by TexMac - 07-18-2010, 08:45 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
