Slug tuned postwar table set, unusual?
I had a Truetone like that. D2210 I think was the number. Plain-Jane octal AA5. I'm surprised the scheme wasn't used more often. Looks simple and cheap.
That radio had a metal cabinet with a curved speaker area. It too had something similar to window screen to protect the grille cloth.
-Bill
Slug tuned postwar table set, unusual? - by tom2 - 07-17-2010, 09:52 AM
Re: Slug tuned postwar table set, unusual? - by exray - 07-18-2010, 09:59 PM
Re: Slug tuned postwar table set, unusual? - by tom2 - 07-19-2010, 04:21 PM
Re: Slug tuned postwar table set, unusual? - by tom2 - 09-10-2010, 10:01 PM
There are currently 10766 online users. [Complete List]
» 2 Member(s) | 10764 Guest(s)
