37-630 chassis in 37-610 cabinet?
(07-09-2018, 06:19 PM)mikethedruid Wrote:  Actually, there were different models of the 37-630...
Right. The 37-630T chassis has the rectifier next to the audio output tube, on the chassis. The 37-630 console chassis has the rectifier tube on top of the power transformer.
I made an assumption that the OP had a 37-630 console chassis in which case my advice is correct regarding use of a 5Y4GA tube. If the OP has a chassis from a 37-630T, he's good to go as far as fit inside a 37-610T cabinet.
RE: 37-630 chassis in 37-610 cabinet? - by Arran - 07-09-2018, 06:21 PM
RE: 37-630 chassis in 37-610 cabinet? - by Ron Ramirez - 07-09-2018, 06:22 PM
There are currently 4623 online users. [Complete List]
» 1 Member(s) | 4622 Guest(s)
