Found it. 275 watts and 2.392 amps.
I found on the internet the label on the radio which shows the radio is 275 watts @ 115 volts giving 2.391 amps.
nv3g
Oscar
Found it. 275 watts and 2.392 amps. - by NV3G - 07-11-2018, 01:08 PM
RE: Philco 38-690 Wattage? - by morzh - 07-11-2018, 01:17 PM
RE: Philco 38-690 Wattage? - by Radioroslyn - 07-11-2018, 01:45 PM
RE: Philco 38-690 Wattage? - by Ron Ramirez - 07-11-2018, 02:52 PM
RE: Philco 38-690 Input Current? - by Arran - 07-11-2018, 05:56 PM
RE: Philco 38-690 Input Current? - by NV3G - 07-11-2018, 07:04 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3655 online users. [Complete List]
» 2 Member(s) | 3653 Guest(s)
