37-116x - audio int trans - Why did it burn out?
Sorry for the late response. I've been busy rebuilding the chassis. It's Done! And it WORKS! No mistakes in over 300 connections. I replaced all wire, caps, resistors, etc. This thing is like new.
Anyway, thanks for the rewinding info. I've never done a re-wind before and I think this would be a great test case. If I fail, no big deal as I have a used, original replacement transformer.
Now on to alignment... and that's a whole new question I have. See new posting.
John
Re: 37-116x - audio int trans - Why did it burn out? - by spfradios2 - 07-25-2010, 12:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
