37-650 Issues
#35
Thanks, Bill- Appreciate the support Icon_smile Now- I have a BNC type connector (Marked "RF Output") on the front of my signal generator (Heathkit IG 5242) and a pair of banana jacks marked "EXT MOD". Which one do I connect to? And what settings should I make? (Range, Millivolts FS, Meter- MOD-RF, Function- CW;MCW;EXT)
I'm GUESSING connect to the BNC, Meter on RF Carrier, Function on CW(Continuous Wave?) and Range???
And how do I measure the result- hook up the oscilloscope somewhere?
Sorry for all the "dumb" questions, but I'm still getting this pulled together on the test equipment part Icon_smile
Thanks!
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
37-650 Issues - by Robbie Roberts - 01-27-2006, 07:06 AM
[No subject] - by Steve Chambers - 01-27-2006, 08:01 AM
[No subject] - by Robbie Roberts - 01-27-2006, 12:07 PM
[No subject] - by Steve Chambers - 01-27-2006, 12:21 PM
[No subject] - by Robbie Roberts - 01-27-2006, 12:32 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:02 PM
[No subject] - by Steve Chambers - 01-27-2006, 06:23 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:29 PM
[No subject] - by Steve Chambers - 01-27-2006, 06:38 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:41 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:51 PM
[No subject] - by Steve Chambers - 01-27-2006, 07:05 PM
[No subject] - by Robbie Roberts - 01-27-2006, 07:44 PM
[No subject] - by Robbie Roberts - 01-27-2006, 09:07 PM
[No subject] - by Robbie Roberts - 01-30-2006, 05:12 PM
[No subject] - by Chuck Schwark - 01-30-2006, 07:53 PM
[No subject] - by Steve Chambers - 01-30-2006, 07:59 PM
[No subject] - by Robbie Roberts - 01-30-2006, 08:02 PM
[No subject] - by Chuck Schwark - 01-30-2006, 08:12 PM
[No subject] - by Robbie Roberts - 01-31-2006, 12:52 AM
[No subject] - by Chuck Schwark - 01-31-2006, 09:57 AM
[No subject] - by Robbie Roberts - 01-31-2006, 11:43 AM
[No subject] - by Robbie Roberts - 01-31-2006, 06:40 PM
[No subject] - by Steve Chambers - 01-31-2006, 08:53 PM
[No subject] - by Robbie Roberts - 02-02-2006, 09:24 AM
[No subject] - by Steve Chambers - 02-02-2006, 05:00 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:47 PM
[No subject] - by Robbie Roberts - 02-02-2006, 06:24 PM
[No subject] - by Chuck Schwark - 02-02-2006, 07:42 PM
[No subject] - by Robbie Roberts - 02-02-2006, 07:43 PM
[No subject] - by Robbie Roberts - 02-02-2006, 08:36 PM
[No subject] - by Chuck Schwark - 02-02-2006, 10:22 PM
[No subject] - by Robbie Roberts - 02-02-2006, 11:03 PM
[No subject] - by Bill Hutchinson - 02-03-2006, 03:20 PM
[No subject] - by Robbie Roberts - 02-03-2006, 03:26 PM
[No subject] - by Bill Hutchinson - 02-03-2006, 07:08 PM
[No subject] - by Robbie Roberts - 02-04-2006, 08:29 AM
[No subject] - by Robbie Roberts - 02-05-2006, 01:42 AM
[No subject] - by 49Stude63 - 02-05-2006, 11:07 AM
