Zenith 7G605 Transoceanic - the Clipper
Well, measure it and see if it is a resistor. Can't be sure but looks like 310 ohms if the arrow is the last digit.
RE: Zenith 7G605 Transoceanic - the Clipper - by codefox1 - 07-12-2018, 10:03 PM
Users browsing this thread: 13 Guest(s)
