Zenith 7G605 Transoceanic - the Clipper
There are 330 ohm on the list but I can't place it: there are discrepancies with the schin how it's hooked up.
340 ohm then. But it measures 24 ohm. In circuit. Maybe due to filaments.
RE: Zenith 7G605 Transoceanic - the Clipper - by morzh - 07-12-2018, 10:43 PM
Users browsing this thread: 13 Guest(s)
There are currently 9305 online users. [Complete List]
» 3 Member(s) | 9302 Guest(s)
