Philco 21 sort of
Terry;
  In case you can't stand those cracks, the veneer that they used on the frond arch on model 21s. 70s, and 90s was something called "orientalwood", at least that's what Steve Davis said they used, so he uses that on his repro cabinets.
Philco 21 sort of - by Radioroslyn - 07-10-2018, 11:47 AM
RE: Philco 21 sort of - by OldRestorer - 07-10-2018, 04:29 PM
RE: Philco 21 sort of - by Arran - 07-13-2018, 05:09 AM
RE: Philco 21 sort of - by Radioroslyn - 07-13-2018, 11:34 AM
RE: Philco 21 sort of - by Phlogiston - 07-13-2018, 12:19 PM
RE: Philco 21 sort of - by Arran - 07-18-2018, 03:03 AM
RE: Philco 21 sort of - by Steve Davis - 07-18-2018, 09:30 AM
RE: Philco 21 sort of - by Radioroslyn - 07-18-2018, 11:12 AM
RE: Philco 21 sort of - by Steve Davis - 07-18-2018, 11:55 AM
RE: Philco 21 sort of - by Radioroslyn - 07-20-2018, 04:31 PM
RE: Philco 21 sort of - by OldRestorer - 07-21-2018, 06:16 AM
RE: Philco 21 sort of - by Radioroslyn - 07-21-2018, 09:43 AM
