37-116x, Disconnecting the Speaker during alignment?
Use the AVC line. They didn't often recommend that in the old days because many service shops would not have had a suitable meter.
Re: 37-116x, Disconnecting the Speaker during alignment? - by exray - 07-25-2010, 09:18 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
