Philco 21 sort of
Hi Arran
It doesn't bother me much. It's been grain filled and a few coats of sealer so It's not as noticeable. After some toner I think it will be even less. Am waiting on a Mohawk order to arrive probably next week. Oh and I'm lazy! If it had a hunk missing I'd give Steve a call.
Philco 21 sort of - by Radioroslyn - 07-10-2018, 11:47 AM
RE: Philco 21 sort of - by OldRestorer - 07-10-2018, 04:29 PM
RE: Philco 21 sort of - by Arran - 07-13-2018, 05:09 AM
RE: Philco 21 sort of - by Radioroslyn - 07-13-2018, 11:34 AM
RE: Philco 21 sort of - by Phlogiston - 07-13-2018, 12:19 PM
RE: Philco 21 sort of - by Arran - 07-18-2018, 03:03 AM
RE: Philco 21 sort of - by Steve Davis - 07-18-2018, 09:30 AM
RE: Philco 21 sort of - by Radioroslyn - 07-18-2018, 11:12 AM
RE: Philco 21 sort of - by Steve Davis - 07-18-2018, 11:55 AM
RE: Philco 21 sort of - by Radioroslyn - 07-20-2018, 04:31 PM
RE: Philco 21 sort of - by OldRestorer - 07-21-2018, 06:16 AM
RE: Philco 21 sort of - by Radioroslyn - 07-21-2018, 09:43 AM
There are currently 9838 online users. [Complete List]
» 2 Member(s) | 9836 Guest(s)
