Replacing a missing speaker
#38
Ok I found my mistake, Resistors R9 250k & R10 1meg are connected at a common point along with Cap C-22 what I did is swap the two other ends. They were located in a tight corner and not easily accessible but my volume is now good. I did the alignment and peaking of 1 & 2 IF's. Even the SW works after some cleaning of the rotary switch. I'll post a picture when I get it together.
Mike
I am curious in your pictures you show a resistor across the tone control mine did not have that nor do the prints show a resistor ?
Eric
Replacing a missing speaker - by Eric - 06-08-2018, 08:56 AM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 10:02 AM
RE: Replacing a missing speaker - by Eric - 06-08-2018, 02:00 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 02:56 PM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 03:03 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 03:21 PM
RE: Replacing a missing speaker - by Arran - 06-09-2018, 02:41 AM
RE: Replacing a missing speaker - by Chas - 06-09-2018, 10:03 AM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 02:40 PM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 03:10 PM
RE: Replacing a missing speaker - by Arran - 06-11-2018, 02:24 AM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 05:50 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 06:20 PM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 07:45 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 07:58 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 11:52 AM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 01:23 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-18-2018, 01:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 03:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 04:00 PM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 05:34 PM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 07:58 AM
RE: Replacing a missing speaker - by KCMike - 06-19-2018, 08:47 AM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 09:50 AM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 01:02 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-28-2018, 04:44 PM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 10:07 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-29-2018, 03:12 PM
RE: Replacing a missing speaker - by Eric - 06-30-2018, 10:14 AM
RE: Replacing a missing speaker - by Radioroslyn - 06-30-2018, 11:47 AM
RE: Replacing a missing speaker - by Eric - 07-02-2018, 03:44 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 02:56 PM
RE: Replacing a missing speaker - by Radioroslyn - 07-10-2018, 03:19 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 05:06 PM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 09:54 AM
RE: Replacing a missing speaker - by KCMike - 07-12-2018, 10:11 AM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 04:18 PM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 09:35 AM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 10:51 AM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 05:01 PM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 07:03 PM
There are currently 8265 online users. [Complete List]
» 1 Member(s) | 8264 Guest(s)
