Philco speaker substitution question.
Hi everybody,
It's been a while since I actually posted a question here, but post a question here, I will. :-)
Will a speaker from a 40-150 fit a 41-255 radio?  Both radios use two #41 output tubes in a push/pull configuration.  I don't actually have the 40-150 speaker so I can't physically or electrically check to see if it will fit and work.  I've got a 41-255 that needs a speaker.  Any thoughts or advice?
Thanks a lot, Tom
Philco speaker substitution question. - by Tom Hamilton - 07-14-2018, 01:24 PM
The speaker table error?
Philco 70 antenna lead
