Zenith 7G605 Transoceanic - the Clipper
The refilled cap and the chassis with some caps replaced (and some are still not).
RE: Zenith 7G605 Transoceanic - the Clipper - by morzh - 07-15-2018, 07:28 PM
There are currently 9919 online users. [Complete List]
» 1 Member(s) | 9918 Guest(s)
