Freed-Eismann NR-10
Hello all.  Picked up a Freed-Eismann NR-10 this past weekend.  I'm admittedly very uneducated with this radio.  The unit is built into a tall boy cabinet.  I've searched the internet and found several photographs of this set, but none with this cabinet.  It appeared too well constructed to have been a conversion.  The set itself is dusty but very well preserved considering it's age.  The filigree is intact, as is the grille cloth.  Cabinet needs a little TLC, but I could only hope to look as good if I ever get to be as old as this console!  If anyone can offer any more information about this radio I would be very appreciative.  Will do everything I can to make this one of my "babies"!  Take care, and thanks in advance, Gary (forgot to add - photos are in July Finds and Losses)
Freed-Eismann NR-10 - by GarySP - 07-16-2018, 11:38 AM
RE: Freed-Eismann NR-10 - by Phlogiston - 07-16-2018, 12:31 PM
RE: Freed-Eismann NR-10 - by Arran - 07-17-2018, 05:25 PM
RE: Freed-Eismann NR-10 - by mikethedruid - 07-17-2018, 07:16 PM
RE: Freed-Eismann NR-10 - by GarySP - 07-19-2018, 09:15 AM
RE: Freed-Eismann NR-10 - by Arran - 07-20-2018, 06:49 AM
There are currently 9931 online users. [Complete List]
» 3 Member(s) | 9928 Guest(s)
