RCA 110K2 Unexpected project
Threads: 44
City: Menlo Park
State, Province, Country: CA
Thanks Arran.
One was in the triode anode circuit... probably tone as you say but it was missing and not replaced by previous restorer..
The others were more closely associated with the 2nd IF, and I indeed was expecting an effect on alignment. The shotgun had hit this set at point blank range long before I came along with the surgical tools and bandages..
I played with the cap tester on some of the oscillator section caps. It is easy enough to disconnect one side for reliable readings.
Cheers,
Ed
RE: RCA 110K2 Unexpected project - by EdHolland - 07-17-2018, 08:48 PM
Users browsing this thread: 25 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9948 online users. [Complete List] » 2 Member(s) | 9946 Guest(s)
