Zenith 7G605 Transoceanic - the Clipper
Yes, Deoxit treatment is in my plans.
As well as many other things.
Next is the tubes testing.
PS. What I liked about this recapping was the wax they used:: very easily melted and extracted. Nice change from the Tropic which was that one that does not melt at all.
RE: Zenith 7G605 Transoceanic - the Clipper - by morzh - 07-18-2018, 10:00 PM
Users browsing this thread: 14 Guest(s)
There are currently 10117 online users. [Complete List]
» 2 Member(s) | 10115 Guest(s)
