BATTERY ACID REPAIR
Depends on your abilities. If the rest of the cabinet is really good, a repair to just the damaged panel would be best. It can be done, but matching grains and colors is not covered in Cabinet Repair 101. (Advanced skills required)
Pitchers?
BATTERY ACID REPAIR - by GarySP - 07-21-2018, 12:03 PM
RE: BATTERY ACID REPAIR - by Phlogiston - 07-21-2018, 12:36 PM
RE: BATTERY ACID REPAIR - by Arran - 07-22-2018, 08:32 AM
Eico 232 VTVM Schematic
