BATTERY ACID REPAIR
We would need to see the damage to make an evaluation, for a start the acid would have to be neutralized in some way before any repair to that panel could be made, no need if it is to be replaced. I can remember neutralizing the battery shelf in the bottom of an old battery console from the late 1930s with a baking soda solution years ago, lots of fizzing action.
BATTERY ACID REPAIR - by GarySP - 07-21-2018, 12:03 PM
RE: BATTERY ACID REPAIR - by Phlogiston - 07-21-2018, 12:36 PM
RE: BATTERY ACID REPAIR - by Arran - 07-22-2018, 08:32 AM
