zenith 9s-367 question
  • Thanks Terry,
  • Main issue i am seeing is it is not really motor boating , but more of a motor beating noise.
    seems to vary with volume. No reception, just noise.Murf
zenith 9s-367 question - by murf - 07-22-2018, 11:36 AM
RE: zenith 9s-367 question - by Radioroslyn - 07-22-2018, 02:32 PM
RE: zenith 9s-367 question - by murf - 07-22-2018, 05:34 PM
RE: zenith 9s-367 question - by murf - 07-23-2018, 08:44 PM
RE: zenith 9s-367 question - by murf - 08-01-2018, 09:56 PM
There are currently 8900 online users. [Complete List]
» 2 Member(s) | 8898 Guest(s)
