Zenith 7G605 Transoceanic - the Clipper
#32
Need the cord for tuning cap: will buy on RR.
Does anyone know the cord winding diagram?
On a sidenote: tested the tubes; all are OK, though the 1LA6 converter has Pentode at 500 at desired 1000. I am sure it will work fine, will replace if available. Oh....I have the second radio. Maybe there it is better.
RE: Zenith 7G605 Transoceanic - the Clipper - by morzh - 07-26-2018, 09:04 AM
There are currently 8512 online users. [Complete List]
» 1 Member(s) | 8511 Guest(s)
