Zenith 7G605 Transoceanic - the Clipper
#33
Mike, I may have a spare 1LA6. Let me know if you want me to dig around the tube boxes.
RE: Zenith 7G605 Transoceanic - the Clipper - by Paul Philco322 - 07-26-2018, 11:24 AM
There are currently 7230 online users. [Complete List]
» 2 Member(s) | 7228 Guest(s)
