Zenith 7G605 Transoceanic - the Clipper
#34
Thanks for the offer. If anything goes wrong, I'll sure take you upon it. Icon_smile
I have just bought a full set of NIB/NOS tubes for 7G605 off of a guy who sells them. Seems like I bought the last one.
per tube it came out better that buying one of them. It will be good to have a spare set just in case.
Then again, I have a second set which is likely to get restored right after the first, so ....
RE: Zenith 7G605 Transoceanic - the Clipper - by morzh - 07-26-2018, 11:59 AM
Users browsing this thread: 20 Guest(s)
There are currently 10702 online users. [Complete List]
» 3 Member(s) | 10699 Guest(s)
