Zenith 7G605 Transoceanic - the Clipper
#36
Antique electronic supply has N.O.S. 1LA6 tubes in stock:
https://www.tubesandmore.com/products/1la6-heptode
RE: Zenith 7G605 Transoceanic - the Clipper - by EdHolland - 07-26-2018, 07:20 PM
Users browsing this thread: 15 Guest(s)
There are currently 10273 online users. [Complete List]
» 2 Member(s) | 10271 Guest(s)
