Advice needed for Philco 116 refinish
Ron,
Do you remember how many cans of toner it took to do your cabinet? I'm ready to order my extra dark walnut, but need to know how many cans to order...I'm cheap, and don't want to order 2 when only one is necessary.
Advice needed for Philco 116 refinish - by don'tdomelikethat - 08-29-2010, 12:54 PM
Re: Advice needed for Philco 116 refinish - by don'tdomelikethat - 09-03-2010, 04:58 AM
There are currently 11269 online users. [Complete List]
» 2 Member(s) | 11267 Guest(s)
