RCA 110K2 Unexpected project
Threads: 44
City: Menlo Park
State, Province, Country: CA
Here is a picture of the IF transformer I checked:
The view is from the primary side, with the small cap soldered between the outermost pins in the phenolic base. In this picture, it is behind the center, unused, pin. An identical arrangement is made on the other side for the secondary winding. Replacing the capacitors would be easy - they desolder without much trouble, and there is room for replacements, but I doubt that this will be required for a long time to come, and the value marked on my schematic differs from what was measured.
Regards,
Ed
RE: RCA 110K2 Unexpected project - by EdHolland - 07-30-2018, 04:03 PM
Users browsing this thread: 29 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10120 online users. [Complete List] » 2 Member(s) | 10118 Guest(s)
