Zenith 7G605 Transoceanic - the Clipper
#52
OK. Can you isolate it to any stage, or see if the noise adds up through the R.F. amp and I.F. stages?
I realise you can't pull valves, but it would be possible to kill the signal at each stage with a cap, and see how noise responds?
Just a thought.
RE: Zenith 7G605 Transoceanic - the Clipper - by EdHolland - 08-05-2018, 05:27 PM
Users browsing this thread: 17 Guest(s)
There are currently 8707 online users. [Complete List]
» 2 Member(s) | 8705 Guest(s)
