Zenith 7G605 Transoceanic - the Clipper
#55
Good progress I'd say Icon_smile
The noise while tuning woukd have bugged me too. The constant noise might be normal... a sign of a design with more gain for small antennas.
RE: Zenith 7G605 Transoceanic - the Clipper - by EdHolland - 08-06-2018, 08:46 AM
Users browsing this thread: 14 Guest(s)
