Atwater Kent 246
I can get these for you, but I'm in the process of moving and my best measuring devices are at the other house.  I'll try to get this done sometime tomorrow, but there will be a problem scanning the drawing of the cabinet curve because neither of our two scanners have beds long enough to do the whole trace.  Maybe I can cut it in half and do two scans.  I haven't had the three radios side-by-side yet, but I suspect all three similar models, the 246, the 217, and the 708 all use the same basic cabinet dimensions, but I'll use my 246 for your measurements.
If you get these from another site or source first please let me know by posting here..... thanks...
Atwater Kent 246 - by dkoczur - 08-07-2018, 08:44 AM
RE: Atwater Kent 246 - by Eliot Ness - 08-07-2018, 10:34 AM
RE: Atwater Kent 246 - by dkoczur - 08-08-2018, 11:50 AM
RE: Atwater Kent 246 - by Eliot Ness - 08-08-2018, 12:02 PM
RE: Atwater Kent 246 - by dkoczur - 08-09-2018, 10:38 AM
RE: Atwater Kent 246 - by Eliot Ness - 08-18-2018, 10:34 AM
RE: Atwater Kent 246 - by dkoczur - 08-18-2018, 07:59 PM
RE: Atwater Kent 246 - by Eliot Ness - 09-05-2018, 11:26 AM
RE: Atwater Kent 246 - by dkoczur - 09-05-2018, 11:58 AM
RE: Atwater Kent 246 - by dkoczur - 11-03-2018, 09:25 AM
RE: Atwater Kent 246 - by Eliot Ness - 11-20-2018, 09:09 PM
RE: Atwater Kent 246 - by dkoczur - 11-21-2018, 03:09 PM
There are currently 3218 online users. [Complete List]
» 1 Member(s) | 3217 Guest(s)
