Philco 38-7
In between jobs, I decided to pull a recent freebie I was given, a 38-7 chassis. When changing out the bakelite block, I noticed some of the tar sealer had melted, like it had overheated, possibly from shorting out. This block is directly across the line voltage input. I checked the main transformer. It's supposed to read 120ohms/130ohms to center tap, or 250ohms total. it reads 193/205 or 398 total.
Would you say the main transformer is damaged? I do have another chassis. I may just rebuild that one, and steal parts from this one.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Philco 38-7 - by PhilcoPhan1936 - 08-09-2018, 02:50 PM
RE: Philco 38-7 - by Olskuul - 08-09-2018, 05:10 PM
RE: Philco 38-7 - by Radioroslyn - 08-09-2018, 06:08 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-09-2018, 09:47 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-10-2018, 05:40 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-10-2018, 06:09 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-13-2018, 05:03 PM
RE: Philco 38-7 - by Radioroslyn - 08-13-2018, 05:30 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-13-2018, 05:48 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-13-2018, 06:11 PM
RE: Philco 38-7 - by Radioroslyn - 08-13-2018, 06:55 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-13-2018, 07:23 PM
RE: Philco 38-7 - by Radioroslyn - 08-13-2018, 09:22 PM
RE: Philco 38-7 - by Arran - 08-13-2018, 09:38 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-14-2018, 04:17 AM
RE: Philco 38-7 - by Ron Ramirez - 08-14-2018, 06:25 AM
RE: Philco 38-7 - by Radioroslyn - 08-14-2018, 08:28 AM
RE: Philco 38-7 - by cpollock - 08-14-2018, 12:30 PM
RE: Philco 38-7 - by Radioroslyn - 08-14-2018, 01:01 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-14-2018, 04:35 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-14-2018, 05:40 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-14-2018, 10:49 PM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-27-2018, 03:34 AM
RE: Philco 38-7 - by PhilcoPhan1936 - 08-27-2018, 07:54 PM
91H Code 126 Restore
