I use Constantine's paste filler to fill in the grain. Walnut toned. Scrape the excess off with a plastic putty knife, then sand lightly.
Others can advise as to the proper color toner to use. Probably Perfect Brown or Medium Walnut by Mohawk.
Personally I prefer a semi-gloss or matt finish, but others prefer a gloss finish. I have both lacquer finishes also from Mohawk.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
37-116 - by JRP3Orion - 08-09-2018, 11:43 PM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 09:59 AM
RE: 37-116 - by KCMike - 08-10-2018, 10:23 AM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 11:32 AM
RE: 37-116 - by Ron Ramirez - 08-10-2018, 12:52 PM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 01:23 PM
RE: 37-116 - by Radioroslyn - 08-10-2018, 01:55 PM
RE: 37-116 - by JRP3Orion - 08-10-2018, 02:39 PM
RE: 37-116 - by Ron Ramirez - 08-10-2018, 02:40 PM
RE: 37-116 - by Ron Ramirez - 08-10-2018, 02:44 PM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 02:49 PM
RE: 37-116 - by Radioroslyn - 08-10-2018, 04:50 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
