It says in the product description: "This product is intended for interior use on open grain woods such as oak, ash and mahogany.  Woodgrain Filler is natural in color, but is best used when intermixed with a solvent-based wood stain to obtain desired colors."
So I thought it might be a good substitute, if it was indeed combined with the proper stain color, as they recommend.
But, once I run out of the Constantine's I have, I'll look for what you recommend Ron, thanks.
Edit: found one place that carries several different flavors of the one you recommend Ron:
https://www.woodworkingshop.com/product/...hDEALw_wcB
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
37-116 - by JRP3Orion - 08-09-2018, 11:43 PM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 09:59 AM
RE: 37-116 - by KCMike - 08-10-2018, 10:23 AM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 11:32 AM
RE: 37-116 - by Ron Ramirez - 08-10-2018, 12:52 PM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 01:23 PM
RE: 37-116 - by Radioroslyn - 08-10-2018, 01:55 PM
RE: 37-116 - by JRP3Orion - 08-10-2018, 02:39 PM
RE: 37-116 - by Ron Ramirez - 08-10-2018, 02:40 PM
RE: 37-116 - by Ron Ramirez - 08-10-2018, 02:44 PM
RE: 37-116 - by PhilcoPhan1936 - 08-10-2018, 02:49 PM
RE: 37-116 - by Radioroslyn - 08-10-2018, 04:50 PM
