38-14 Cabinet Veneer Question
Hello to all,
I have a Philco 38-14 cabinet with water damage to the top as well as missing/damaged veneer.
I want to replace the top with a new piece of plywood and veneer.
It looks like the main pieces of veneer are a match for "french walnut".
So my question is does anyone know what wood was used for the inlay? I was thinking the grain looked like walnut but I am not sure. Maybe a different cut?
Or could it be that its all the same type of wood veneer (french walnut) with just a different color toner?
Ron
38-14 Cabinet Veneer Question - by radio49 - 08-10-2018, 04:20 PM
RE: 38-14 Cabinet Veneer Question - by KCMike - 08-10-2018, 05:01 PM
RE: 38-14 Cabinet Veneer Question - by radio49 - 08-10-2018, 07:36 PM
RE: 38-14 Cabinet Veneer Question - by Arran - 08-10-2018, 10:17 PM
RE: 38-14 Cabinet Veneer Question - by radio49 - 08-11-2018, 04:53 PM
RE: 38-14 Cabinet Veneer Question - by Arran - 08-12-2018, 02:07 AM
Philco 91 Tuning Condenser
There are currently 6829 online users. [Complete List]
» 2 Member(s) | 6827 Guest(s)
