Philco 16B
Hi all
I have two questions on a Philco 16 B cathedral:
1 Is the top/sides walnut?
2 Does the grain run from front to back?
I have a cabinet that needs the veneer replaced (it has been removed by someone else Icon_sad ) I have never put veneer on a cabinet but have to try sometime I guess. Icon_biggrin
So wish me luck Icon_rolleyes
Joe
Philco 16B - by w4rtc - 10-18-2010, 02:54 PM
Re: Philco 16B - by Ron Ramirez - 10-18-2010, 05:34 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 02:11 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 02:20 PM
Re: Philco 16B - by DeckApe - 10-20-2010, 04:12 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 05:11 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 07:16 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 07:26 PM
Re: Philco 16B - by Steve Davis - 10-21-2010, 10:11 PM
Re: Philco 16B - by w4rtc - 10-21-2010, 11:09 PM
There are currently 9164 online users. [Complete List]
» 3 Member(s) | 9161 Guest(s)
