45F - What to do?
Thanks very much for the info - accurate on all counts. I clipped across the volume pot and got about halfway through a Sinatra/Dorsey album when one of the electrolytics busted and sent out a jet of...whatever's in an electrolytic capacitor. I really like this radio, though, and I think I'll take it in to my tech for a re-cap.
C.B.
45F - What to do? - by Guest - 08-08-2010, 06:24 PM
Re: 45F - What to do? - by rghines1 - 08-09-2010, 09:25 AM
Re: 45F - What to do? - by Ron Ramirez - 08-09-2010, 02:45 PM
Re: 45F - What to do? - by Guest - 08-09-2010, 08:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
