Zenith 7G605 Transoceanic - the Clipper
#59
which brings me to a particular question of curiosity....
you have to wonder how the factory tuned and aligned sets when bad weather was near.. it should have had an effect on calibrating things i would think.. perhaps not...dono, i wasnt there.
RE: Zenith 7G605 Transoceanic - the Clipper - by jcassity - 08-18-2018, 10:50 AM
There are currently 9728 online users. [Complete List]
» 2 Member(s) | 9726 Guest(s)
