Zenith 7G605 Transoceanic - the Clipper
#62
JCassity;
  I am not sure how they went about aligning radio receivers at the factory, the IF alignment would be easy enough, but I'm guessing that they aligned sets in a shielded room to keep out electrical interference, perhaps employing a Faraday cage. This is one detail that I have not seen elaborated on in any book or film that I have seen.
RE: Zenith 7G605 Transoceanic - the Clipper - by Arran - 08-19-2018, 12:53 AM
Users browsing this thread: 17 Guest(s)
There are currently 8585 online users. [Complete List]
» 2 Member(s) | 8583 Guest(s)
