Next Restoration Project- 1929 Victor R-32 Radio
Thanks for the insight Mjeansonne, This will be my second restoration once I get started, so I'm just beginning. Any and all recommendations are well accepted and appreciated!
Gregg Icon_thumbup
There are currently 9774 online users. [Complete List]
» 2 Member(s) | 9772 Guest(s)
